I3d Question
pld
Hi All,
I've created a POPnet which has metaballs attached to particles. I'm happy with the simulation however I wanted to know if there's a way to control the color and alpha of the particles when using i3d. I can easily do it if I use a surface shader (using the pointSOP) to render the metaballs... is it possible to do it with the VEX3D texture FOG? Would I have to write my own i3d shader?
thanks for your help!
Hi All,
21468[/snapback]
To control the "alpha" I would just use copy stamping to control the weight of the metaball.
This will control the density of each metaball and hence control the alpha.
for color you'll need to modify one of the existing i3d shaders so that it writes out an i3d image
with an extra channel for color. In order to get the color off of the metaballs you'll need to make
use of the vex function mattrib(). I think someone has already done this and posted it on odforce,
so have a look around.
feel free to ask questions if you run into trouble
Luca
Luca
21471[/snapback]
Hi Luca,
if I change the weight of the metaballs, won't this simply affect their pulling power with respect to other metaballs? What I'm trying to achieve is smoke that gradually disappears after some time. The way it is set up at the moment is annoying because the particles die after a given time and this results in smoke vanishing from one frame to another...Hence was trying to fade out that effect
patrick
For some reason I can't stamp $ALPHA only $LIFE for my stamping expression for the metaball weight. Any thoughts as to why?
21491[/snapback]
The copy sop is limited to the local variables that it supports have a look at the help card
for a list. That being said, $LIFE is supported by the copy sop, so it should work.
for a variable like $ALPHA, or any other attribute, you'll want to use the point expression.
type:
exhelp point
in the textport to see the help.
the point expression to retrieve the alpha value would probably look something like this:
point("../mySopWithAlpha",$PT,"Alpha",0)
let me know if you run into trouble
Luca
