an2050 Posted December 29, 2017 Share Posted December 29, 2017 Hi people! Please tell me how to properly fix the topology. After using the boolean operation I'm getting a problem with the topology. What should I do to apply extruding correct after boolean operation. I tried use the sop Clean and sop PolyDoctor, this did not work. Thank you! topology_repair.hipnc Quote Link to comment Share on other sites More sharing options...
f1480187 Posted December 29, 2017 Share Posted December 29, 2017 (edited) Input should be fixed instead: Go to Display Options (D key in viewport) > Optimize tab > enable "Remove Backfaces". That artist friendly default is bad, since the side does matter in modeling. After reversing geometry (Reverse node or just use positive extrude) try Subtract B - A, everything will work well: Edited December 29, 2017 by f1480187 1 Quote Link to comment Share on other sites More sharing options...
an2050 Posted December 29, 2017 Author Share Posted December 29, 2017 Thank you my friend! it's nice! Quote Link to comment Share on other sites More sharing options...
