Emit Constrained, Fractured Packed RBDs from the Debris emission of RBDs splitting apart.
HM_2020
Hello, thanks for any help in advance!
I know there are a few threads and tutorials out there for something similar, but I can not seem to find anything on exactly what I need.  Seems like everyone emits particles from geo using SOPsolvers, but not simply an actual particle emission from DOPS.  I thought it would be simple to swap out the SOP emission with POP emission but it eludes me.
I have some concrete blocks, fractured with booleans and constrained, falling and breaking apart.
I am emitting particles (using Debris tool) from the fracture as it breaks.  All fine so far.
I want to then rotate/transform more fractured packed primitive RBD chunks (also constrained!) instanced to the particles (which die after 1 frame, just need their velocity and rotation), that then will break into smaller bits.
It seems simple to setup but again I can not figure out how to mix it all together in one DOP that works correctly.
Bottom line is I need to have a few large RBD bits fall and break, emit smaller chunks using particles, without having to actually fracture the large bits into tons of pieces.  I want to use this Debris/Packed Prim technique to save memory and large scale RBD sims.
Any help is greatly appreciated, sick of banging my head! :D
