BrookerT Posted January 2, 2018 Share Posted January 2, 2018 Hello! So I'm not sure if I should be posting this in a Maya forum, but I'm having issues with constrained objects in Houdini. The object was rigged in Maya and then exported to be rendered in Houdini, but when brought into Houdini, on certain frames the parent constraints freak out and cause a weird effect ( show in the picture ) I've narrowed it down to the objects that are being parented. I've tried to delete the constraint and just parenting under the geo, still no luck. Has anyone else ever encountered this? If so what did you do to fix it? Thanks Quote Link to comment Share on other sites More sharing options...
coltonmil Posted January 3, 2018 Share Posted January 3, 2018 Hey BrookerT, Have you tried baking the animation of the object to keyframes in world space and then deleting the constraints? Quote Link to comment Share on other sites More sharing options...
