UV mapping on a sweep
AntoineSfx
I'm trying to set the UV correctly on this brick arch:
On top it's a bent box, but I'd like to do it with a rectangle + sweep
I got u from curveu from the resample node, and  v from the fact that points are in such an order that the bottom ones are easily found with a formula
@uv[1]=(@ptnum%4)/2;
Then a uvtransform downstream to tweak things in uv space.
But.. this adds coupling between two nodes (# sides of the polygon <-> formula) , and obviously it's fragile.
What's a better way to have u along the curve, and v normally to the curve (and maybe then in the z /  depth direction too) ?
This after the cross section
@curvev=(float)@ptnum/@numpt;
copied later with
@uv[1]=@curvev;
also works, and requires to have a third node where I have something to setup on uv..
arch.hipnc
