mnordenstam Posted September 29, 2005 Share Posted September 29, 2005 Hi gurus, Simple problem: how do I access the radius of the bounding sphere of a set of points? I tried feeding my points into a sphere SOP, which does create a bounding sphere, but then when I want to access the radius I call ch("/obj/my_object/bounding_sphere/radx") but this always returns 1, no matter what the bounding sphere's radius really is. there has to be a simple solution to this, eh? thanks markus Quote Link to comment Share on other sites More sharing options...
exel Posted September 29, 2005 Share Posted September 29, 2005 mnordenstam said: Hi gurus,Simple problem: how do I access the radius of the bounding sphere of a set of points? I tried feeding my points into a sphere SOP, which does create a bounding sphere, but then when I want to access the radius I call ch("/obj/my_object/bounding_sphere/radx") but this always returns 1, no matter what the bounding sphere's radius really is. there has to be a simple solution to this, eh? thanks markus 21548[/snapback] It's returns a value of 1 because it's referencing the value of the parameter, not the actual sphere that's being generated... you'll notice those parameters are grayed out when you've got something plugged into the sphere input, I guess that's to mean the Radius parameter is being overridden... Anyway, try using a bbox expression to measure the bounding size of the geometry and then take half of that to get the radius: bbox("/obj/my_object/bounding_sphere",D_XSIZE)*.5 Quote Link to comment Share on other sites More sharing options...
mnordenstam Posted September 29, 2005 Author Share Posted September 29, 2005 Thanks! That did the trick... markus exel said: It's returns a value of 1 because it's referencing the value of the parameter, not the actual sphere that's being generated... you'll notice those parameters are grayed out when you've got something plugged into the sphere input, I guess that's to mean the Radius parameter is being overridden... Anyway, try using a bbox expression to measure the bounding size of the geometry and then take half of that to get the radius: bbox("/obj/my_object/bounding_sphere",D_XSIZE)*.5 21549[/snapback] Quote Link to comment Share on other sites More sharing options...
