rootboot00 Posted January 15, 2018 Share Posted January 15, 2018 (edited) Hi guys I make some scene with using RBD fractured objects. That is screenshot of simple scene and I have some problem with this. As you see, I made the desk and chair and make those each glue constraint in their node too(with different constraint name and type. Not in screenshot but I made each's constraint networks and glueconrel node. I connected each nodes just like when I made it by shelf tools, but It didn't work. (I saw tutorial about constrain and made this scene differently with when I make it by shelf tools.) and I could find why it didn't work. At that screenshot, when I put Chair node into merge node on top first input, Chair's glue constraint is work. and when I put Desk node into merge node on top, first input. Desk's glue constraint is work. It doesn't matter constrainnework's Sop path or glueconrel's Data name. How could I fix this that merged objects follow each's constraintnetworks and glueconrel ??? Thank you for read and sorry for my poor Englis. T_T Thank you ! (I changed options in the merge node like Affector relationship and relationship, but It didin't work :S) Edited January 15, 2018 by rootboot00 Quote Link to comment Share on other sites More sharing options...
rootboot00 Posted January 15, 2018 Author Share Posted January 15, 2018 I finally fixed it to solve it, I compared all shelf-made(glue constraint) nodes with my hand made nodes. shlef nodes uses 'Attribute String Edit' node. Inside of it, at Editor tab, they write `chs("/obj/its dopnet name/rbd packed object name/object_name")`/*. for making 'name' attribute to 'its name'+piece number so I write it same and finally I can control each object's glue strength. now I'm wondering about Attribute string edit node and 'chs' function. could anyone explain about it for me ? Quote Link to comment Share on other sites More sharing options...
