export camera?
I cannot find this anywhere. How do you export a camera from Houdini? Here is what I tried: I created a new geo node, then object merge node, merged the camera then changed transform to into this object. I used a file node then export. When you import it, the camera is there and moves correctly, but when you go to choose camera there is no camera to choose. I tried creating a camera, then changing the defcam.bgeo to my directory, but that did not work either. What do I do? My end goal is to export a camera to another houdini scene and to maya.
Thanks
