Bgeo, Bclip And Bchan File Format Specs
Does anyone know where I can find documentation on the bgeo, bclip and bchan file format specs?
I just need to know about the headers and the data types..etc. and if thereare any wierd bit offsetting.. the usual file parsing mess. Unfortunately I do not have a licence of the HDK, I'm only interested in it from outside of houdini (writing a maya plugin to read bclip and bchan).
Thanks
Austin
Hmm.. thats too bad. As the binary files are significantly smaller on disk than the ascii versions. But if you say they are subject to change without notice, ascii it will be.
Austin
The binary versions of those files are not supported as they're subject to change without notice. Please use the ASCII versions of those files (ie. same extensions but without the b ).
21628[/snapback]
