Weird point connection(for my purpose)
MFatnes
Hey Martin,
There are 2 ways to achieve what I believe you're looking for.
The easiest way would be to do your add SOP before the merge.
The second way would be to make an attributeCreate SOP before the merge on each side. You can make the attribute almost anything, as long as it's consistent for both sides. But to stay inline with most naming conventions for multiple pieces:
Attribute Name: name
Attribute type: string
String: piece1
(piece2 for the other input, etc.)
Then in your add sop in the by group tab set Add to "By attribute" and put name as the attribute name.
