"Bind" two buttons together
JJ FX
So I need to somehow "bind" two buttons together, but only one direction relation. When I press A, the B need to run too. I was hoping "pase relative references" would do (the button is a 0 - 1 state, so why not), but unfortunately not.
Do I need to use somekind of callbacks for that? Any example would be most owesome.
Edited by JJ FX
So I've found this:
hou.parm('myNodeA/myButtonA').pressButton()
And this has to probably go to button B (A -> B ) into callback script, right?
What if I already have there something in callback script in button B... ?
Edited by JJ FX
you can also do a right click copy parameter, paste relative parameter references,
but this does not work with buttons directly, instead paste them on a dummy node on the same hierarchy level, and then copy the resulting hexpression.
right click on the button, go to edit parameter expression and paste it there.
in that way it should work too.
also if you want multiple callbackscripts on one button, just add a ";" in between :)
