Using A Pic As Texture From Local Network
I want to use a pic as texture from local network. I can't browse for local network with houdini's UI, how to?
But I found I can get into it with //computer name/..../xxx.jpg
with this address, I can see the texure in SHOPs, and I can also see it in the openGL viewport, but I can't render it with mantra.......
I worked with houdini-8[1].0.383-win32. Is it a bug?
It seems that I should copy all the files for every machine to same directory (i3d,textures,and so on) if I want to use mantra netrender????? Not like renderman doesn't need to copy such files to every machine.:(
