UV Flatten distorted plane
nuki
I am trying to generate nice, relaxed UVs for a distorted grid object. Ideally I would want to simply relax the initially generated UVs after distorting it but all the tools available seem to be focused on generating new UVs altogether. Having never done this kind of thing in Houdini I also struggle to understand how I could procedurally constraint eg. the outline of the grid to a square or all the points with @P.x==0 to a straight line.
UVs pre distortion
UVLayout post distortion
Quickly generated UVs in maya to outline what I'm after
river_UV.hip
Edited by nuki
Smoothing geometry may help a bit. It will leave UVs straightened and tileable and reduce interpolation zigzags. It will also help UV Flatten to output proper geometry without such big distortion.
Also you may try Delta Mush, it may simulate results you need. Swap UV with P, then apply DM on straightened UVs using UV Flatten output as a second input:
delta_mush_uv.hipnc
  • Like 2
  • 1 year later...
I am reviving this thread because I am dealing with a similar problem, except that my model has several UV islands instead of one big island like the example above. The DeltaMush approach did not work for me beacuse of the UV islands. DeltaMush needs point attributes. When converting the UV attribute from vertices to points I lose the UV islands because of the connectivity of the points at the edges of the vertex islands.
What I want to achieve is the following:
1. create an initial UV layout with several uv islands (UV Flatten)
2. deform the geometry
3. relax the initial UVs to compensate for the distorted geometry from step 2
I am struggling to make the above DeltaMush approach work with UV islands. Any ideas?
Maybe someone has a completely different idea how to relax the UVs after the geometry deformation. My geometry is only deforming slightly. I am looking for a way to match the edge lengths/primitive areas of the UVs with the new (deformed) edge lengths/primitive areas of my mesh.
Edited by a41b
  • 2 weeks later...
I have posted a RFE which is now implemented. Thanks SideFX :D
UV Relaxation of existing UV islands is now a feature of the UV Flatten node when "Preserve Seams" and "Preserve Layout" is turned on in Houdini 17.5.319.
  • Like 2
