JJ FX Posted February 20, 2018 Share Posted February 20, 2018 (edited) Hi, So I scripted some custom behaviour to work in network view. It works great. However now I would like to somehow assign a key shortcut to it. So besically "press S" > "run script"... BTW Im talking here about python script Edited February 20, 2018 by JJ FX Quote Link to comment Share on other sites More sharing options...
f1480187 Posted February 20, 2018 Share Posted February 20, 2018 Create a shelf tool from the script. You will find Hotkeys tab here: Quote Link to comment Share on other sites More sharing options...
JJ FX Posted February 20, 2018 Author Share Posted February 20, 2018 3 hours ago, f1480187 said: Create a shelf tool from the script. You will find Hotkeys tab here: Most owesome, big thanks Quote Link to comment Share on other sites More sharing options...
JJ FX Posted February 21, 2018 Author Share Posted February 21, 2018 (edited) Actually I have found that after restarting houdini all shortcuts are lost... Any idea how to fix that? BTW I think its because of that. it looks like I cannot edit this. It only works for a running session. Once closed, all keys are lost. And I cannot see my scripts in hotkey manager (edit > hotkeys...) Edited February 21, 2018 by JJ FX Quote Link to comment Share on other sites More sharing options...
ikoon Posted February 21, 2018 Share Posted February 21, 2018 Maybe you should check, that you erased the other W, the default W from Network Pane? As in the attached image. Also you may look in this file: C:\Users\...\Documents\houdini16.5\Houdini.keymap.overrides Quote Link to comment Share on other sites More sharing options...
JJ FX Posted February 22, 2018 Author Share Posted February 22, 2018 Yeah... Looks likemy file is setup the same way. However still this does not work. Im on apprentice version, maybe thats the issue Quote Link to comment Share on other sites More sharing options...
