vex function
mir
hi there...
i have just started working on VEX...
wat i'm trying to do is that i wanna compare the velocity attributes of two particles...for eg. particle ID 5 and particle ID 10...
how should i go about doing that...
the poppoint() function does not work in VEX!!!it would have made things really simple...
Mir
Hey,
check out the import function.
int import(string attrib_name; vector &result; int input, pt_num)
you can import any attribute from any point of any input.
so to import the velocity of point 10, you'd:
import("v",newV,0,10)
so the velocity of point 10 will be put into vector `newV`.
Cheers,
Jens
