catchyid Posted February 25, 2018 Share Posted February 25, 2018 (edited) Hello, I am wondering if someone has encountered this problem before on Houdini 16.5.268? In summary, I have a pyro cluster setup and it works fine IF Pyro solver "Max Substeps" =1 , however when I increase it two 2, for example, Houdini crashes? As a workaround, I've tried to increase simulation substeps of the parent dop node and it did not work (also a crash), and as a last resort, I've tried to divide the parent dop node Timestep by two (effectively having substeps=2), but it also I get a crashe?! Just a clarification, I need more substeps because I have high initial smoke velocities, so without substeps smoke look "dotty"... Edited February 25, 2018 by catchyid Quote Link to comment Share on other sites More sharing options...
