Vex Expression Question
Graham Hutchings
I'm a Houdini Newbie and my first post here.  I'm following a tutorial on Pop Grains which is very good.
Tutorial is here :
https://vimeo.com/132847114 [vimeo.com]
TimeCode : 37:20
Towards the end he adds a proximity point and calculates 1000 grains to fall every frame based on the distance to the point. The expression used on the force node is :
force*=@id <(@Frame *1000);
I've been trying to get 50 grains to fall per frame until it reaches frame 50. At 50 frames and above I would like 1000 grains to start to fall per frame.
Is this possible with expressions ?
Thanks
Hello,
I'm not very familiar with this type of code but if you replace the "1000" with a variable that change after f.50, I think i'll do the trick.
float nb = 50;
if(@Frame > 50)
    nb = 1000;
force *= @id < (@Frame * nb);
Also, if someone could take the time to explain me this type of code I would be glad to know a bit more about it!
Gabriel
Alternativly, if you want to continue the "boolean" multiplication approach, you could also write something like this:
force *= @id < (@Frame-50)*1000 || @id < @Frame*50;
@Nache Boolean expressions in Houdini return 0 for false and 1 for true, just what you did in the if statement. So the force just gets multiplied by the result of the expression.
