jelen Posted March 3, 2018 Share Posted March 3, 2018 Hey guys do you have an idea how to make this kind of aurora effects and use audio to drive its motion thank you so much. Quote Link to comment Share on other sites More sharing options...
LaidlawFX Posted March 5, 2018 Share Posted March 5, 2018 So this is going to be a simple answer, but create a line with many points, and drive that through chops. After importing from chops, use a polyframe to orient your normals, copy lines to them to create the height, and skin it. If you apply UVs to the line, you can modulate the transparency from top to bottom. It already looks pretty CG'd up as is, so even a slap comp will do. Quote Link to comment Share on other sites More sharing options...
