Solver with vdb erode and animated geo
MrMarceu
Good morning everyone!
I'm trying to create a foam on an animated geometry, that animated geometry is a face, and I used vdb to create the foam, i wanna know if have a way to use the Solver (SOP) to use a vdb erode of a shaver for example with a volume vdb on it, to cut the foam when it passes through the vdb of the foam, i've tried to use vdb on solver, even boolean, in static geometry it works very well, but in animated ones don't.. Somebody can help? Thanks!
Hugs!
Felipe Marceu
