Network Popup....
michael
hey...
I wrote this little thingy that I find really usefull...maybe you will too....
once setup you can RMB on a network/subnet/OTL/etc and select [popUp] and a floating pane will 'popUp' that displays the contents of that network...
go to your $HOME/houdiniX.X
and look for a file called OPmenu
add these lines:
# Objects
Object/* popUp "[Pop Up]" $HOME/houdiniX.X/scripts/popUp.cmd
#SOPs
Sop/* popUp "[Pop Up]" $HOME/houdiniX.X/scripts/popUp.cmd
then add the attached file to your $HOME/houdiniX.X/scripts/ directory
NOTE : you may have to monkey with the file paths depending on how you're set up...
popUp.zip
