michael Posted October 14, 2005 Share Posted October 14, 2005 here's another one.... ever want to jump into a network/OTL/etc and dread the thought that the display is on something that will take a week to cook?...well dread no more! now all you have to do is RMB on a network/OTL/etc and select Add Display Null, and this script will...er...add a null and set it's display flag to on....now you can stroll into the network/OTL/etc without a care in the world... go to your $HOME/houdiniX.X and look for a file called OPmenu add these lines: # Objects Object/* addDisplayNull "Add Display Null" $HOME/houdiniX.X/scripts/addDisplayNull.cmd (should be all on one line) #SOPs Sop/* addDisplayNull "Add Display Null" $HOME/houdiniX.X/scripts/addDisplayNull.cmd (should be all on one line) then add the attached file to your $HOME/houdiniX.X/scripts/ directory NOTE : you may have to monkey with the file paths depending on how you're set up... addDisplayNull.zipFetching info... Quote Link to comment Share on other sites More sharing options...
