anupamd Posted October 15, 2005 Share Posted October 15, 2005 Hi guys, I am still having trouble writing out a proper bchan file from an app that I'm writing. Yes I know bchan may change in the future as a format and hence it's better to write to chan but .. I still want to write to bchan for it's compactness and also faster to load. It's a bit frustrating trying to reverse engineer bchan and i'm close but no cigar. I loaded the .bchan file in to vc++ and noticed a "chan" header. So I wrote that. Then included the interleaved data a.k.a chan float float float float... float float foat float ... so this seems to be ultra simple except houdini still does not see my .bchan file. I just need the bchan format documentation, and if I had that I'd be set. Or if someone can post an example. As allways, thanks for the help! Austin Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted October 15, 2005 Share Posted October 15, 2005 Don't have time to dig into this right now for ya, but maybe this will help: http://twinforces.com/tf/docs/tool_rec2chan.html --Mark Quote Link to comment Share on other sites More sharing options...
anupamd Posted October 16, 2005 Author Share Posted October 16, 2005 Don't have time to dig into this right now for ya, but maybe this will help:http://twinforces.com/tf/docs/tool_rec2chan.html --Mark 21886[/snapback] Oh yea, I found that and was like WOOHOO time for a beer! But no beer. The link to the source files is password protected as clicking on the link to dnld causes a "This is a private system-No anonymous login" If anyone has this source, please let me know. Austin anupam_das@hotmail.com Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted October 16, 2005 Share Posted October 16, 2005 Oh yea, I found that and was like WOOHOO time for a beer! But no beer. Thelink to the source files is password protected as clicking on the link to dnld causes a "This is a private system-No anonymous login" If anyone has this source, please let me know. Austin anupam_das@hotmail.com 21892[/snapback] I have the source but may not be able to get it to you until Monday, having just put in a 14 hour day Saturday and likely the same Sunday. It's on one of my old IRIX boxes at home plus I know the developer and will contact him should I have trouble finding it on my machines. --Mark Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted October 16, 2005 Share Posted October 16, 2005 If anyone has this source, please let me know. 21892[/snapback] Here ya go: --Mark Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted October 17, 2005 Share Posted October 17, 2005 :coffee1: Did that help you out? OK, time to snoooooz ZZZZZZZZZZZZZZZZZZZZZZ --Mark Quote Link to comment Share on other sites More sharing options...
anupamd Posted October 17, 2005 Author Share Posted October 17, 2005 Mark THANK YOU!!! and I hope you got some rest!!! This helps extremely, all the header code I need is right there. I havent yet tested the code yet as I'm not near my dev box but I'm sure it will all be fine. Again, thanks very much for stepping forward and helping with this issue! If you are local (Cali), I'll buy you a beer! or coffee Austin :coffee1: Did that help you out? OK, time to snoooooz ZZZZZZZZZZZZZZZZZZZZZZ --Mark 21904[/snapback] Quote Link to comment Share on other sites More sharing options...
Jason Posted October 17, 2005 Share Posted October 17, 2005 Out out curiosity - did you know that you could write out .chan files and feed them through chcp which I believe can convert from ASCII to binary format chans. I haven't tried it at all. Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted October 17, 2005 Share Posted October 17, 2005 Out out curiosity - did you know that you could write out .chan files and feed them through chcp which I believe can convert from ASCII to binary format chans. I haven't tried it at all. 21907[/snapback] Yea, it's handy, especially for the *really* large channel files! --Mark Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted October 17, 2005 Share Posted October 17, 2005 Mark THANK YOU!!! and I hope you got some rest!!!This helps extremely, all the header code I need is right there. I havent yet tested the code yet as I'm not near my dev box but I'm sure it will all be fine. Again, thanks very much for stepping forward and helping with this issue! If you are local (Cali), I'll buy you a beer! or coffee Austin 21906[/snapback] Hi Austin, Glad it helped out. I'm in NYC but will be in LA early next year and just might take you up on the offer! Let me know if you run into any problems. --Mark P.S. No sleep yet ... damn computers! Quote Link to comment Share on other sites More sharing options...
