henderthing Posted October 17, 2005 Share Posted October 17, 2005 What, exactly, does this parameter do when there is only one input? When I use it to get the position of the neighbor of every nth point, and have a single input--the result changes dramatically when i use different values for OP input index. Shouldn't it just fail? What's going on here? (to clarify--my understanding was, in the case of a SOP VOPnet where multiple SOPS are connected to the VOPnet SOP's inputs, the OP input index was used to select which connected SOP is evaluated--and that input zero is appropriate for 1 input) Thanks -m Quote Link to comment Share on other sites More sharing options...
edward Posted October 17, 2005 Share Posted October 17, 2005 So what's wrong with your understanding? That's how I understand it as well. Quote Link to comment Share on other sites More sharing options...
henderthing Posted October 18, 2005 Author Share Posted October 18, 2005 The problem is that I have only one input, but when OP input index is set to 0, nothing happens (appears to fail), as I go to 1, 2, 3 etc...the vopnet is doing something--something different for each index, for that matter. Is OP input index sensitive to primitives or groups in some way that I don't understand? The input SOP in question has a dozen primitives, and four point groups and the VOPnet cycles to doing nothing on every 4th input index beginning with 0... I'm confused. -m edward said: So what's wrong with your understanding? That's how I understand it as well. 21933[/snapback] Quote Link to comment Share on other sites More sharing options...
edward Posted October 18, 2005 Share Posted October 18, 2005 But if you have only 1 input into your SOP, then only an input index of 0 makes sense to be used in the Import Attribute VOP, right? Behaviour of using non-existent inputs would be undefined. Quote Link to comment Share on other sites More sharing options...
henderthing Posted October 18, 2005 Author Share Posted October 18, 2005 well...yes. which is why i had it that way, and only began messing with it as the importAttrib node was failing to do anything with index at 0. I think it has something to do with the way i'm trying to use the neighbor vop beforehand. I'm only operating (if block) on points that pass the test of $PT%5 ==2 test, then, inside the if block, I want to get info from a neighboring point. It sure seems like everythign is OK---but the importAttrib node is failing. Miserably. If i connect its adata output directly to P output, nothing happens. Remembering that I'm working on the 3rd point of every 5, that point should move to it's neighbor's position. AH!--more tests show that there is a problem with my neighbor vop. It doesn't like negative numbers. It would appear that I've misused it. I wanted to go back 2 points from the current point. Turns out it's better--much--to just subtract 2 from point number on the way into the importAttrib vop. I've got a lot to get used to... I'm still curious what the heck the opindex thingy was doing there... Thanks for making me look harder elsewhere! -m edward said: But if you have only 1 input into your SOP, then only an input index of 0 makes sense to be used in the Import Attribute VOP, right? Behaviour of using non-existent inputs would be undefined. 21935[/snapback] Quote Link to comment Share on other sites More sharing options...
