FEM in 16.5
vegardaarhus
Hi. Im trying to constraint points on a FEM object in H16.5 but cant select any points to constraint.
Have anyone had this issue?
I use the shelf tools, then do the following.
1- Constrain points to target
2- try to select objevct i vewiport, dont work, have to select it in Node menu/dop menu
3-cant select any of the points on my object in dops.
In H16 i animated the Geo in sops, then added constraints to some points in Dops, then it worked.
But i intalled 16.5 today, and i cant select any points. Im kind of lost. Ive read about upodates in H16.5 put i could not find any answer.
Let me know if i didnt explain this good enough.
SOLVED: i had to use a visibility node in sops to mark my tetras.
fem_poins_issue.hiplc
Edited by vegardaarhus
