MasonStyle Posted March 21, 2018 Share Posted March 21, 2018 (edited) Hello there! I'm fairly new to Houdini and brand new here in the forums. I'm trying to create a Star Wars like "jump to lightspeed" setup in Houdini. So far I'm almost done, but now I'm struggling with the look of the splines. I like the look of the tube (Splines and then Polywire node), I just wish there was somehting like a sphere at the end, or rather a sphere as a cap. Is there an easy way to attach something to the endings of the tube/spline? Of course i tried the Cap Node, but I can't make it work... Here's a quick render and the file: hyperjump.hip Edited March 21, 2018 by MasonStyle Quote Link to comment Share on other sites More sharing options...
MasonStyle Posted March 21, 2018 Author Share Posted March 21, 2018 Ok I've figured it out. I use a sphere and the copy to points node! Quote Link to comment Share on other sites More sharing options...
dgani Posted March 21, 2018 Share Posted March 21, 2018 You might try using the wireframe node instead of the poly wire node. That can create rounded edges. http://www.sidefx.com/docs/houdini/nodes/sop/wire.html Quote Link to comment Share on other sites More sharing options...
MasonStyle Posted March 21, 2018 Author Share Posted March 21, 2018 Genious! That's even better, thanks a lot! Quote Link to comment Share on other sites More sharing options...
