repeat length animation
chumbucket
Hi.
I do have a DOP network which creates points.
On those points I'm copystamping a line.
I want to animate the length of the line starting with the birth of aforementioned points. So for every birthed point the length should start with 0 and reach a certain value in 1 sec.
Here is a mock-up of what it should look like.
I have no clue where to start. timeshift, for each loop, vops, vex.
Edited by chumbucket
You could use the particles age and life attributes and write them into a scale attribute in a wrangle like so:
// Normalize the age by dividing it with the life attribute, this will give a value between zero and one
float nage = @age/@life;
//Because nage is a float variable it will be copied three times in the vector scale attribute
v@scale = nage;
Then plug this into a copy sop with your line geo at the maximum length you want.
  • Thanks 1
Thanks Sean!
Just to clear it up for others.
1. create a wrangler after the pop net
2. in the wrangler write
//f@length because I just want to manipulate the length of the line and not the whole scale. Idon't want to fudge with the initial velocity I have set //previously. The 50 is just a multiplier. You could "ch" it for more convenience aswell
f@length = nage*50;
3. In the copy sop tick on "Stamp Inputs" and create a variable "length" with the value "@length" referencing the previously created attribute from the wrangler
4. write this in the length parameter of the line sop
//the line geo will look up the value from the copy sop. "0" is the default value
stamp("../copy1/","length",0)
