nigelgardiner Posted April 5, 2018 Share Posted April 5, 2018 Hi there I've had this issue for a couple of days and I can't figure it out. I thought my Flip sim was bad because playing back the .sim files didn't seem to advance the simulation past the first frame for a number of frames and then it jumps ahead in time. However if I reset the simulation and manually tab in the next frame instead of advancing the timeline the next frame of the simulation is actually there. I'm wondering if the issue is related to my dop network simulation settings in any way? For some reason the start frame is 0 and the offset time is -0.016667. I don't recall setting start frame to 0 so I may have inadvertently change it as I have my other dops set to start frame 1. All my dops are running with a scale time of 0.5 and 5 sub steps. Global FPS is 60. I'm not having any problems with the other dops, it's just this last flip that won't play back correctly. Any advice much appreciated. I've attached the hip. thanks Nigel. double size btl with cond v23 rf wking.hiplc Quote Link to comment Share on other sites More sharing options...
