kwilli30 Posted October 10, 2002 Share Posted October 10, 2002 Hi folks! I'm a new houdini user working through the "volumetrics using Image3d". I'm stuck when I need to add an Atmosphere Object. It doesn't appear in the generators menu, and the Houdini User Guide isn't being helpful either... Thanks in advance Quote Link to comment Share on other sites More sharing options...
TheUsualAlex Posted October 10, 2002 Share Posted October 10, 2002 Hey Kev, Umm.. I mean, kwilli Having fun with Houdini You have to generate the I3D texture through the I3D output first in Houdini. You can find the tutorial at: http://www.odforce.net/tips/i3d_intro_page1.php Augh. I am so tired. Thinking about skipping eng class today to sleep. cheers, man. ALex Quote Link to comment Share on other sites More sharing options...
kwilli30 Posted October 10, 2002 Author Share Posted October 10, 2002 Alex, Yup, that's the turorial, and I got as far as the atmosphere object...I generated the id3, do I need to load it in again? Skipping class? *sigh* Thanks Quote Link to comment Share on other sites More sharing options...
TheUsualAlex Posted October 10, 2002 Share Posted October 10, 2002 Hmm.. I'll have to get back to you with those later. I've only used the Texture3D stuff back in H5.0 beta. It seems like this stuff has been really popular in Garman's class. FIgured I might as well go back to the basics and experiment it it again. Be sure to come to the Lucas tonight and bring your questions to Steve. Quote Link to comment Share on other sites More sharing options...
mir Posted October 22, 2002 Share Posted October 22, 2002 ok....once u've generated the i3d files , u create a volumetric atmosphere SHOP in there u import in the i3d file sequence. after that u go to the object level and create an atmosphere object...and in the atmosphere object u specify your volumetric shader as the SHOP volumetric shader u created earlier - this links up your atmosphere object to the i3d textures. Hope this helps!! Quote Link to comment Share on other sites More sharing options...
