Debris source
breadbox
Can you get unique point id's from the "debrissource" SOP tool?
I need this because the "scatter points" have an age and so they die which tosses ptnum out the window for instancing. It seems like ID would be a built in option for this sort of thing?
yea i noticed you could dive into it but wasn't sure the "standard" way to make an id... looks like in this case its just ptnum.
In the case of the debris asset, I was worried about using id=point number because it seemed to adding, removing and changing point numbers on the output and creating an id based on that might lead to bad or inconsistent results. Now I see that you added the ID before the point culling "visualization" wrangle happens which makes it work.
Now I also know how to also add in a rest position! It looks like this mysterious asset at its heart is a fancy scatter points.
Cool!
