lisux Posted October 26, 2005 Share Posted October 26, 2005 Hi all again .... I want to know the fastest method to include an operator in an existing subnetwork in the same network. Sometimes i have a subnetwork and then create new operator wired to the output of the previous subnetwork, and then i want to include these new operators into the subnetwork. this is a common task when modelling for example. At the moment i know two ways, cut the operators, go into the subnetwork and paste them in. Extract the subnetwork, select the new operator and the operators extracted from the subnetwork and create a new subnetwork with them. I don Quote Link to comment Share on other sites More sharing options...
sibarrick Posted October 26, 2005 Share Posted October 26, 2005 You could use network boxes instead, then all you need to do is drag and drop them inside the perimeter of the network box. Quote Link to comment Share on other sites More sharing options...
lisux Posted October 26, 2005 Author Share Posted October 26, 2005 You could use network boxes instead, then all you need to do is drag and drop them inside the perimeter of the network box. 22147[/snapback] Thanks simon, i know about the network boxes. Quote Link to comment Share on other sites More sharing options...
