AntoineSfx Posted April 15, 2018 Share Posted April 15, 2018 (TSP= traveling salesman problem) So I'm trying to animate an arm, which would spray paint on a surface. I want to define a curve with respect to a surface, with those properties: 1/ cover the entire surface, within a radius (paint is sprayed within a cone) 2/ offset to the surface, and always on the same side -- every point on the final curve (not only control points) should be at a certain distance along the normal of the surface 3/ somehow minimal in length, but not necessarily. I have a first draft for the trajectory, which is really simple: scatter some points on the surface, then sort the points by spatial locality. However, it doesn't generate TSP-style trajectory, there are big jumps, which happen to cross the surface (violates the same side constraint -- 2) How can I do this without going full TSP ? Quote Link to comment Share on other sites More sharing options...
