Cracking Ice Explicet Shapes
wavesmack
Ok,
Im acutally a halo specialist.. my 3d expertise is mediocre with master... BUT i need to solve this problem:
I want a large surface of ice with a depth of x units.. to crack using an l-system that i shaped into a logo.
the logo needs to look like it is cracking in a continuous loop then the logo itself falls into the ice leaving the water in its place.
I know this might be a cliche' revival of a daffy duck cartoon... but it needs to be photo real EXTREME.
I have managed to fail in several ways:
i create lsys shape that cuts plane by using projection... but i thought if i extruded it into a solid line.. i could boolean in out of a surface that way. Not working. Then i tried to use this lsys line to cut the planes geometry in 2. that didnt work for me. I used a translate node to get my plane and 2d lsys to line up.
There isnt a ice_break.pdf anywhere on the net that i can find. So i am really hoping the answers are here with you fine folks. I can find a solution in the search that solves it.. only brings it up a few times.
Like the earth cracking might help if there was a solution for it there.
feel free to email me, AND post it here if you know.
thanks a million in advance,
chris maynard -cmivfx
