Vex Point Clouds Without A .bgeo ?
meshsmooth
I have thought about using the vex point cloud tools to process geometry but it looks to be the case that you must read the point cloud data from a file and you can't read it from somewhere like a sop within the network. So is that the case? I believe i could write the geometry to a file with a ROP output, but this is not as desirable as reading from a sop in the network.
