fatema Posted November 9, 2005 Share Posted November 9, 2005 Hello, I am creating a scene with rolling fog going through an alleyway. I need to know if anyone has a cool fog shader for this procedure for Houdini. Thanks, Fatema Quote Link to comment Share on other sites More sharing options...
altbighead Posted November 9, 2005 Share Posted November 9, 2005 have you looked into this tutorial? http://odforce.net/tips/i3d_intro_page1.php Quote Link to comment Share on other sites More sharing options...
fatema Posted November 9, 2005 Author Share Posted November 9, 2005 Thanks I just saw that. I'll play around with the attributes and hopefully it will work fine. Fatema Quote Link to comment Share on other sites More sharing options...
lisux Posted November 10, 2005 Share Posted November 10, 2005 Mmmm, before using 3d textures i would try to use a simple volumetric light with Z maps, maybe it would be enough. If you nedd more control, for example you wnt to use a particle sistem for the fog the you should use 3d textures, see altbighead post, or point clouds. But if you only need a simple fog effect with a little of noise in the fog i think that a volumetric light can do the work. Quote Link to comment Share on other sites More sharing options...
fatema Posted November 10, 2005 Author Share Posted November 10, 2005 Yeah, I am using a particle system. What do you mean by altbighead post? Mmmm, before using 3d textures i would try to use a simple volumetric light with Z maps, maybe it would be enough.If you nedd more control, for example you wnt to use a particle sistem for the fog the you should use 3d textures, see altbighead post, or point clouds. But if you only need a simple fog effect with a little of noise in the fog i think that a volumetric light can do the work. 22502[/snapback] Quote Link to comment Share on other sites More sharing options...
