lisux Posted December 12, 2005 Share Posted December 12, 2005 Hi all. I am using Houdini 8 with ubuntu 5.10 and Window Maker 0.92. i have used this window manager in the past without problems, but now when i maximize the houdini window a little part in the right side of the screen is not covered by the maximized window, even more, Window Maker has an option to maximize to full screen the window, when i try this with a Houdini Window i get that the bottom part of the screen is not covered. Is a very strange behaviour. It only occur with Houdini windows. Have anydoby experimented this weired behaviour with other window managers, or has solved the problem under window maker? Thanks Quote Link to comment Share on other sites More sharing options...
crunch Posted December 13, 2005 Share Posted December 13, 2005 I'm using xfwm4 (but with Gnome, not xfce). I've had to set HOUDINI_OVERRIDE_YRES to something smaller than my yres. This is so that the top window decorations actually show up on screen rather than just off screen. You might be able to set HOUDINI_OVERRIDE_XRES/HOUDINI_OVERRIDE_YRES to fix your problem. Quote Link to comment Share on other sites More sharing options...
