Incorrect Mirror Weights Colour
altbighead
Are your bones matching correctly between the left and right sides? Are your spines bones in both lists? Easiest way to see is to look at the parameters in the CaptureMirror SOP. Note that the order matters.
23230[/snapback]
eh.. sorry my bad .. there's a option called Point Coloring in CaptureMirror OP and I need to set it to Color by Capture Region to see the feeback.
hehe me thinks it is a another default trick.. :unsure:
