Guest xionmark Posted December 14, 2005 Share Posted December 14, 2005 Hi there, When using the following expression: `objlightmask($OBJ, fa)` in a mental ray SHOP for determining the light mask (which has this expression set as default), the string it returns is NULL. However, when doing something like: `objlightmask("/obj/model", fa)` the light list is returned correctly. So it appears $OBJ is not expanding correctly. I thought $OBJ was a valid variable in any context where one needs to get the object name. Bug? Work around? Thanks! --Mark Quote Link to comment Share on other sites More sharing options...
edward Posted December 14, 2005 Share Posted December 14, 2005 I have no idea about $OBJ, but from a syntactic point of view, should $OBJ have double quotes around it? Quote Link to comment Share on other sites More sharing options...
Guest xionmark Posted December 14, 2005 Share Posted December 14, 2005 edward said: ... should $OBJ have double quotes around it? 23255[/snapback] Hi Edward, That's what I thought too, I tried it, still doesn't work. --Mark Quote Link to comment Share on other sites More sharing options...
