Passing Commands To Hscript On Start Up
doc
Here's my dilemma, I want to start hscript from the textport of an open houdini session.
after opening hscript I want to execute the openport command
something like:
unix "hscript myfile.hip"
unix "openport 77000"
The only problem with this is the unix command will spawn two separate processes.
I tried the following:
unix "hscript myfile.hip; openport 77000"
but his doesn't work either, rather than executing openport in hscript it's trying to execute it in
the shell.
I also tried:
unix "hscript myfile.hip\; openport 77000"
and
unix "hscript myfile.hip < openport 77000"
without success, anybody have any ideas?
many thanks
Luca
24158[/snapback]
As an alternative to Edward's suggestion, you could wrap the hscript launching in a simple Python script that you call instead (ie 'unix "launchHscriptAndOpenPort myFile.hip 77000"') where launchHscriptAndOpenPort would look something like (I haven't tested this, so there may be typos):
#!/bin/python
import os
import sys
file  = sys.argv[ 1 ]
port  = sys.argv[ 2 ]
houdini = os.popen( "hscript "+file, "w" )
houdini.write( "openport "+port )
os.wait()
houdini.close()
I'm also not sure if this only works on Linux or not (I seem to remember os.wait() is not a Windows-happy function). Wow, ok, so maybe this isn't the most versatile suggestion after all ;)
24186[/snapback]
thanks Rob,
I actually ended up using popen2 to open hscript with the optional .cmd as Ed suggested.
And then I used openport to send commands to the hscript session.
Your method looks better though. I should just be able to send commands straight to
hscript and bypass the whole openport buisness completely.
Thanks!
Luca
