Fattak Posted April 23, 2018 Share Posted April 23, 2018 Hi, I've not compiled an HDK plugin in a while. I'm trying to compile HDK plugins for H16.6 now, and I notice that there's a new scheme to access parameters. I can't find any documentation on how to create these new *.proto.h headers that are now required. Could anyone point me to documentation on this, if it's available. I'm using SCons to build my plugins. Here's where I'm stuck: SOP_Star.C:34:28: fatal error: SOP_Star.proto.h: No such file or directory compilation terminated. Compile failed Thanks in advance for the pointers. Quote Link to comment Share on other sites More sharing options...
Stalkerx777 Posted April 26, 2018 Share Posted April 26, 2018 (edited) CMake generates this .proto file at build time. This recently introduced feature allows you (optionally) decouple parameter interface code from the main code. Again, it's not required to do it that way, unless you have special intentions like supporting compiled blocks feature for example or adding a "verb" (see docs) to your plugin. Now, if you absolutely necessary to use SCons, AND you have a code which uses this new paradigm (like SOP_Star.C) take a look at CMakeLists.txt file, you'll see houdini_generate_proto_headers function, which lives in toolkit/cmake/HoudiniConfig.cmake file. Implement it in your SCons script if you want. Cheers. Edited April 26, 2018 by Stalkerx777 Quote Link to comment Share on other sites More sharing options...
Fattak Posted June 8, 2018 Author Share Posted June 8, 2018 Yup, thank you ... Houdini also ships with a python script that does this, generate_proto.py which is also called by the cmake build. Thank you Quote Link to comment Share on other sites More sharing options...
friedasparagus Posted June 24, 2018 Share Posted June 24, 2018 (edited) Hello! Just wanted to jump on this one, as I'm struggling to work out how to create multiparms via a DS file/string. Does anyone have a working example to go from? So far I'm really enjoying the approach, but this has me proper stumped :/ Many thanks, Henry EDIT: Don't know what was going on before, but I obviously managed to do something squiffy... maybe I missed a '#'. Turns out the following is just fine { name parameters multiparm { name "locations" parm { name "enable#" label "Enable#" type toggle default { "0" } joinnext } parm { name "pos#" label "Position#" type vector size 3 default { "0" "0" "0" } } } } Edited June 24, 2018 by friedasparagus I suck Quote Link to comment Share on other sites More sharing options...
