RickWork Posted February 26, 2006 Share Posted February 26, 2006 Hello, I'm using point instancing with mantra and my instances are oriented the wrong way. I have the normals set in a point sop to 0 1 0 . So I expect them to point up! As a test I'm using the famous teapot and it looks as if the teapots are randomly oriented. Anyone knows what's going on here? Maybe I'm just tired and my eye are playing tricks on me. haha. Thanks! /Rick Quote Link to comment Share on other sites More sharing options...
TheUsualAlex Posted February 26, 2006 Share Posted February 26, 2006 Hello, Have you set your up vectors? Typically, just a normal alone my not be enough and you generally would need to provide another perpendicular vector to create a plane and lock your orientation.... Otherwise, even with a single vector, there's still 2 possible axis to rotate from. HTH Alex Quote Link to comment Share on other sites More sharing options...
RickWork Posted February 26, 2006 Author Share Posted February 26, 2006 Hello,Have you set your up vectors? Typically, just a normal alone my not be enough and you generally would need to provide another perpendicular vector to create a plane and lock your orientation.... Otherwise, even with a single vector, there's still 2 possible axis to rotate from. uhmn nope I didn't! Makes sense though.. Gonna try that as soon as I get back to to work. Thanks! /Rick Quote Link to comment Share on other sites More sharing options...
deecue Posted February 27, 2006 Share Posted February 27, 2006 hey rick, might be too late on this one but your instancing geometry can have normals in whichever way direction you want.. however, your instanced geometry must be oriented in the positive zed direction in order for it to follow the normals of the instancing geometry.. hth, dave Quote Link to comment Share on other sites More sharing options...
RickWork Posted February 27, 2006 Author Share Posted February 27, 2006 hey rick,might be too late on this one but your instancing geometry can have normals in whichever way direction you want.. however, your instanced geometry must be oriented in the positive zed direction in order for it to follow the normals of the instancing geometry.. hth, dave 25112[/snapback] Thanks! /Rick Quote Link to comment Share on other sites More sharing options...
