Parameters For Compiling Mith Nmake
kroko
Only a 'simple' question using the HDK (under Windows). What are the command line options for compiling with nmake? I can't find any example.
nmake ... SOP_Parent.c ???
Excuse me but I have no experience with the nmake-utility...
Thanks kroko - a newbie
I just tried this and here's what I found.
First, the Makefile.win file is missing the system includes. So you need to first modify it to include the PlatformSDK stuff like so:
SYSLIBINC = -LIBPATH:$(MSVCDir)/lib -LIBPATH:$(MSVCDir)/PlatformSDK/lib
INCINC = $(INCDIRS) -I$(HFS)/toolkit/include -I$(HFS)/custom/include -I$(MSVCDir)/include -I$(MSVCDir)/PlatformSDK/include
So now where you have your HDK file, you need to create a file named Makefile with something like this:
DSONAME = SOP_Star.dll
SOURCES = SOP_Star.C
!INCLUDE $(HFS)/toolkit/makefiles/Makefile.nmake
Now to compile, you can just invoke nmake with no command line arguments:
nmake
You probably want to modifiy Makefile.win so that it copies the created .dll to $HOME/houdini8.0/dso as well though or else you will have to manually do this after compiling for Houdini to pick it up.
nmake
25187[/snapback]
Thanks for your tips. All works fine but at least I get this error:
!IFNDEF OPTIMIZER
OPTIMIZER = -Ox
!ENDIF
!IFDEF MSVCDIR
MSVCDir = $(MSVCDIR)
!ENDIF
!INCLUDE c:/Program Files/Side Effects Software/Houdini 8.0.410/toolkit/makefiles/Makefile.win
OBJECTS = $(SOURCES:.C=.o)
CC = $(CC:/=\)
LINK = $(LINK:/=\)
!IFDEF DSONAME
.C.o:
echo Compiled on: > taginfo
date /T >> taginfo
time /T >> taginfo
echo by: %USERNAME%@%COMPUTERNAME% >> taginfo
!IFDEF SESI_TAGINFO
echo $(SESI_TAGINFO) >> taginfo
!ENDIF
c:/Program Files/Side Effects Software/Houdini 8.0.410/bin/sesitag -c -f taginfo > tagdefines
$(CC) $(OBJFLAGS) -DMAKING_DSO @tagdefines $< $(OBJOUTPUT)$@
del taginfo tagdefines
$(DSONAME): $(OBJECTS)
$(LINK) $(SHAREDFLAG) $(OBJECTS) $(DSOFLAGS) $(DSOOUTPUT)$@
!ENDIF
!IFDEF APPNAME
.C.o:
$(CC) $(OBJFLAGS) $< $(OBJOUTPUT)$@
$(APPNAME): $(OBJECTS)
$(LINK) $(OBJECTS) $(SAFLAGS) $(SAOUTPUT)$@
!ENDIF
************* HERE COMES THE ERROR ***********
all: $(DSONAME) $(APPNAME)
************* ERROR MESSAGE ******************
NMAKE (39) fatal error U1077: 'C:\Program' return code '0x1'
clean:
del /F /Q $(OBJECTS) $(APPNAME) $(DSONAME)
It seems that there is a problem with the variable $(APPNAME)
Any Idea ?
Thanks kroko...
