Rafal123 Posted March 14, 2006 Share Posted March 14, 2006 Hi people, Can someone explain how second example "pcCloud", from pointCloudsPresentation on Exchange, works? There is a particle object and simple sphere geo. Sphere doesn't interesect with particles but after rendering it does. Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted March 14, 2006 Share Posted March 14, 2006 As far as I can see, it uses a point cloud to speed up the lighting (and self-shadowing) calculation. Instead of sampling at each step in the march, it samples/shades neighbouring cloud points and filters them over some radius. But Luca visits here sometimes, so maybe he can give you a more in-depth explanation. Quote Link to comment Share on other sites More sharing options...
doc Posted March 15, 2006 Share Posted March 15, 2006 But Luca visits here sometimes, so maybe he can give you a more in-depth explanation. 25645[/snapback] Sorry Mario, I've moved to LA so It may be a while before I swing by Axyz I'm a bit busy at the moment so I can't talk too long. I can barely remeber my presentation, but I assume that you guys are talking about the fog shader that uses point clouds. As Mario noted, the lighting is calculated on the points in the point cloud rather than at each point in the raymarch. As I remember it there was a fairly significant flaw with my shader that Andrew Clinton managed to track down. I can't remeber what it was, maybe Andrew might remember. Andrew? Luca Quote Link to comment Share on other sites More sharing options...
