Nuke And -v Flag
deecue
Hey everybody,
this ties in to my thread about using mplay to view aov's.. luckily nuke can view these and with the nuke -v command, this should work quite well.. but I'm having a heck of a time getting it to view multiple images along the frame range.. i.e. :
nuke -v image_rgb.exr image_aov.exr 1,2
any nuke users out there that can help with this?
thanks,
dave
ok.. cool.. a step in the right direction.. (i was using *)..
so now what if i want to do multiple files with different names..
i.e.
image_foo.0001.exr
image_bar.0001.exr
with mplay, i can simply use regular shell expressions:
mplay image_???.0001.exr
or if they aren't the same suffix length
mplay image_*.0001.exr
but can i do this with nuke?
thanks for the help so far.. a big help..
  • 2 weeks later...
btw, this was sort of resolved.. still doesn't look like reg exp can be used which sucks but atleast it does take multiple file names:
nuke -v foo.exr bar.exr
just instead of using a frame range, it cycled through a 1-1 range on each image with the space bar.. the only bad thing about this was it was crazy unstable with 15+ images.. not good..
basically all options came down to creating a .nk script with tcl to bring in each file needed and throwing them into a switch with an expression of the frame number.. (also some shuffling for aovs in to rgb for easy viewing..)
hey alex,
sorry for the late reply.. busy times at work these days..
anyways.. yea, that works fine.. problem wasn't with a sequence of images of the same name, but just random single frames from all over.. i.e.:
$SHOT/hello/foo.0001.exr
$SHOT/world/bar.0001.exr
it does work.. with the space bar.. but breaks easily.. and the user can't go back and forth.. unless i wanted to script out a temp directory with a bunch of symlinks pointing at the original frames from all over, i can't use the %04d method..
thanks again.. :)
