Alain2131 Posted May 2, 2018 Share Posted May 2, 2018 (edited) Hello there ! I'm looking for a way to replicate the "prune small skin weights" of Maya into Houdini. I've found the capture correct node, in which I can clamp the weights. The thing is, the bones are still weighted to the points, just with a zero weight. I want the bone to be removed from the list altogether. Is there a way of doing that ? The "Regions to Remove" field sounds promising, but I haven't been able to do anything with it. If you can answer the previous question, then the rest is not usefull anymore. But if you can answer it too, I'll be a happy little Houdini user grateful. Instead, I tried to do it manually. I dropped down a capture attrib unpack and a python node in which I recreate the arrays without the zero-weight bones. The thing is, I can't find how to create an array attribute on the points ! What is the correct syntax ? I've tried node = hou.pwd() geo = node.geometry() geo.addAttrib(hou.attribType.Point, 'myAttrib', [ 1, 2, 3 ]) but this creates 3 attributes myAttrib[0] myAttrib[1] myAttrib[2]. Thanks ! delete bone from skin.hipnc EDIT : Real-time update : Figured how to create an array attribute : geo.addArrayAttrib( hou.attribType.Point, "myAttrib", hou.attribData.Float, 1 ) geo.addArrayAttrib( hou.attribType.Point, "myAttrib", hou.attribData.Float, 1 ) But now I've got to figure how to populate it. Edited May 2, 2018 by Alain2131 Quote Link to comment Share on other sites More sharing options...
Alain2131 Posted May 3, 2018 Author Share Posted May 3, 2018 Well, I figured out how to do it in VEX. int success = 0; // Don't know why this is not optional float data_array[] = pointattrib( 0, "boneCapture_data", @ptnum, success ); float index_array[] = pointattrib( 0, "boneCapture_index", @ptnum, success ); for( int i=0; i<len(data_array); i++ ) { pop(f[]@boneCapture_data); // Would need a more efficient way to clear the current point's array data pop(i[]@boneCapture_index); } for( int i=0; i<len(data_array); i++ ) { if(data_array[i] != 0.0 ) { setpointattrib( 0, "boneCapture_data", @ptnum, data_array[i], "append" ); setpointattrib( 0, "boneCapture_index", @ptnum, index_array[i], "append" ); } } I heard that Python is pretty slow compared to VEX, so I thought why not. And it turned out easier to do. delete bone from skin_1.hipnc Quote Link to comment Share on other sites More sharing options...
Alain2131 Posted May 3, 2018 Author Share Posted May 3, 2018 Sorry for double-post (triple if we count yesterday's), but here's a little change in logic, should be more optimized now : for( int i=0; i<len(f[]@boneCapture_data); i++ ) { if(f[]@boneCapture_data[i] == 0.0 ) { setpointattrib( 0, "boneCapture_data", @ptnum, slice( f[]@boneCapture_data, 0, i ), "set" ); setpointattrib( 0, "boneCapture_index", @ptnum, slice( i[]@boneCapture_index, 0, i ), "set" ); break; } } Cheers ! Quote Link to comment Share on other sites More sharing options...
