update corresponding parameters tab
JJ FX
So in my script im using hou.Node.setCurrent() for selecting nodes. But I noticed that my parameters tab does not update when I select nodes like that.
How do I update the corresponding parameters tab to the selected node with .setCurrent() ?
12 minutes ago, ikoon said:
Now I have tried this, it should work better?
node = hou.node('/obj/geo1')
parm_pane = hou.ui.curDesktop().paneTabOfType(hou.paneTabType.Parm)
parm_pane.setCurrentNode(node)
The method setCurrentNode() is not yet documented, but arguments are here:
http://www.sidefx.com/docs/houdini/hom/hou/PathBasedPaneTab.html
yeah this method is nice as long u use one network and one params tab.
Will dive into setCurrentNode() and PathBasedPaneTab....
