Ocean surface problem
crippmint
When this happens usually the issue is in the displacement bound. Looks like your displacement bound parameter in the ocean surface shader isn't high enough.
You should increase it a little bit, but carefully. The render will take more memory and probably more time. I usually go something like a third higher until the artifacts disappear. But it depends a lot from the scene
