noc2 Posted May 13, 2018 Share Posted May 13, 2018 Hi; I have a vector array spat out by a node upstream and would like to access that array downstream in an attribute wrangle node that runs on details also. Below is what I tried to no avail, the vectors stored in the array are not returned somehow: foreach(int i; vector aaa; v@vec_array){ v@av = aaa; } I want to be able to create points by running through all the vectors in this array. Thanx in advance for all the help; AJ Quote Link to comment Share on other sites More sharing options...
j00ey Posted May 13, 2018 Share Posted May 13, 2018 This will do it points_from_vector_array.hiplc Quote Link to comment Share on other sites More sharing options...
noc2 Posted May 13, 2018 Author Share Posted May 13, 2018 Thanx so much Tim, that helped tremendously Houdini documentation is great but I sometimes get the feeling that it is possible to find one's self in the dark about certain things. Thanx so much again for taking the time to help cheers; AJ Quote Link to comment Share on other sites More sharing options...
