VEX - create primitives from arrayvalues
-HEAVY-
Hey Folks,
I wrap my head around this and cant find any solution
can somebody explain me why this is not working and how I can get it to work ?
// roomsizes
vector zim3    = {5.25, 2.50, 3.82};
vector zim2    = {3.65, 2.50, 3.90};
vector zim1    = {3.65, 2.50, 2.82};
vector kueche  = {2.50, 2.50, 3.82};
vector bad     = {2.83, 2.50, 3.74};
vector flur    = {1.50, 2.50, 5.71};
vector aRaum   = {1.50, 2.50, 0.96};
// create Rooms
// create _LivingRoom
int pos0 = addpoint(0, {-(zim3.x*0.5), 0, -(zim3.z*0.5)});
int pos1 = addpoint(0, {(zim3.x*0.5), 0,  -(zim3.x*0.5)});
int pos2 = addpoint(0, {(zim3.x*0.5), 0, (zim3.z*0.5)});
int pos3 = addpoint(0, {-(zim3.x*0.5), 0, (zim3.z*0.5)});
int roomPrim0 = addprim(0, "poly");
int vert0 = addvertex(0, roomPrim0, pos0);
int vert1 = addvertex(0, roomPrim0, pos1);
int vert2 = addvertex(0, roomPrim0, pos2);
int vert3 = addvertex(0, roomPrim0, pos3);
seems very simple but I miss something...
and yes i am running in Detail mode
thx
deHeavy
Edited by -HEAVY-
You should use set() instead of {} when you mix numbers and variables.
// roomsizes
// create Rooms
int pos0 = addpoint(0, set(-(zim3.x*0.5), 0, -(zim3.z*0.5)));
int pos1 = addpoint(0, set((zim3.x*0.5), 0,  -(zim3.x*0.5)));
int pos2 = addpoint(0, set((zim3.x*0.5), 0, (zim3.z*0.5)));
int pos3 = addpoint(0, set(-(zim3.x*0.5), 0, (zim3.z*0.5)));
yeah thx again, I read a lot at the moment and try and type and script and so on. I watch Entagma and read through Tokeru and others - but it seems that I missed that one.
Ohh and i found the line that "explains" the use of the set attribute - i really didnt get it before (around an hour or so).
Edited by -HEAVY-
so know that it works I have different primitives how do I access those primpoints separatly for shifting them around etc. ?
ahh never mind i use the primnumber
Edited by -HEAVY-
