syntheticperson Posted May 30, 2018 Share Posted May 30, 2018 I want to be able to export custom attributes from inside my own copy of the classic shader. I also want to be able to feed inputs into my custom shader, at the Material Network level. However, there appears to be a conflict. When there are no inputs at the Network level, then the custom attribute is visible in the extra image plane in my mantra node. However, as soon as I connect anything to any input at the Material Network level, then the custom image plane becomes black/zero. Any ideas? I have documented the example hip file with post-it notes, from scene level all the way down to the shader level for navigation. thanks customShaderMaterialArbitraryExportBug.v01.hipnc Quote Link to comment Share on other sites More sharing options...
