rakson Posted June 6, 2018 Share Posted June 6, 2018 Hi, ive got problem with narrow band flip simulation and unfortunately i can't share my scene file. My problem is that my flip sim was ok, but after changes of collider velocity multiplier my simulation starting to drop. Im using Narrowband flip with oceansource, container is following my collision object. Any tips? Quote Link to comment Share on other sites More sharing options...
acey195 Posted June 6, 2018 Share Posted June 6, 2018 not really an expert, or user of flip at all to be honest, but I did recall this showing up in the changelog, worth a try I guess?: Houdini 16.5.483 Reseeding in the flipsolver is now forced to be active when narrow band is active. This is important because the simulation can collapse with narrow band if the band of particles are not maintained properly. Thu. May 24, 2018 Quote Link to comment Share on other sites More sharing options...
rakson Posted June 6, 2018 Author Share Posted June 6, 2018 33 minutes ago, acey195 said: not really an expert, or user of flip at all to be honest, but I did recall this showing up in the changelog, worth a try I guess?: Houdini 16.5.483 Reseeding in the flipsolver is now forced to be active when narrow band is active. This is important because the simulation can collapse with narrow band if the band of particles are not maintained properly. Thu. May 24, 2018 thanks, last time i checked it was in the middle of may so it wasn't even mentioned as fix;) Quote Link to comment Share on other sites More sharing options...
vinsonlws Posted October 25, 2018 Share Posted October 25, 2018 On 2018-06-06 at 5:28 AM, rakson said: thanks, last time i checked it was in the middle of may so it wasn't even mentioned as fix;) hi I had the same problem about my flip tank, could you tell me how you fixed it or some tips how to avoid the dropping? thanks so much Quote Link to comment Share on other sites More sharing options...
rakson Posted November 10, 2018 Author Share Posted November 10, 2018 On 10/25/2018 at 3:56 AM, vinsonlws said: hi I had the same problem about my flip tank, could you tell me how you fixed it or some tips how to avoid the dropping? thanks so much Hi, sorry for late reply. In my case it was enough to change version for newer;) Quote Link to comment Share on other sites More sharing options...
